Subfile Header not formatted by autogui
[email protected]
Subfile header fields are defined in DDS as DSPATR(UL) but the underline is missing from some fields in aXes. The ones that are not underlined are missing the ax_x24o class attribute. Any ideas?
- html.png (18.4 KiB) Viewed 24573 times
- axesscreen.png (5.12 KiB) Viewed 24573 times
- ul.png (2.13 KiB) Viewed 24573 times
Re: Subfile Header not formatted by autogui
Hi Nic
You can create an application style that uses CSS selection rather than the X attribute drop down
Style for HTML Element
HTML Tag: div.ax-terminal-field.x24 span
Style: do your underline
for5250Attributes: leave blank
[email protected]
Thank you Tim
