Subfile Header not formatted by autogui
[email protected]
Post by [email protected] »
Subfile header fields are defined in DDS as DSPATR(UL) but the underline is missing from some fields in aXes. The ones that are not underlined are missing the ax_x24o class attribute. Any ideas?
Re: Subfile Header not formatted by autogui
Post by tim mcentee »
Hi Nic
You can create an application style that uses CSS selection rather than the X attribute drop down
Style for HTML Element
HTML Tag: div.ax-terminal-field.x24 span
Style: do your underline
for5250Attributes: leave blank
[email protected]
Thank you Tim
