how to recognize input or text?
Let's say you have a screen like this:
and you identify the input field as input01, and the text field as txt02.
but sometimes when you get to this screen, txt02 happens to be an input field.
so I want to be able to know from the script in aXes if it is an output text, or an input field.
checking in the developer tools, I can see that this is the code associated with this two fields:
<div id="ifld602" class="ax-terminal-field x24 ui-widget" title="" style="top: 112px; left: 15px; visibility: visible; width: 26px; height: 21px;">
<input type="text" maxlength="2" size="2" class="ax-terminal-inputField ax_x24i ui-widget-content" style="width: 26px;"></div>
<div id="text607" class="ax-terminal-field x20 ui-widget" title="" style="top: 112px; left: 80px; visibility: visible; width: 117px; height: 21px;">
<span class="ax-terminal-textField ax_x20o" style="">  QPASVRS</span></div>
the input field is inside a div that starts with ifldxxx and the text file is inside a div that start with txtxxx.
Can I read that name from the script in aXes?
I have tried a silly
alert(FIELDS("txt02").getProperty("id"));
but getProperty do not get me that close. maybe need to indicate some sort of parent. Any ideas?
Re: how to recognize input or text?
nevermind, found the solution.... I just ask for the Element in that row and colum... if I find an ifld, then i know is an input field. If I found a text in that row, column, it is an output field.
var theElement = document.getElementById("ifld607");
if (theElement === null)
    var theElement = document.getElementById("text607");
        alert("nothing here")
    else
        alert("output field");
else
    alert("input field");
Post by tim mcentee »
aXes has a utility for this
FIELD.isInputField
or
FIELDS("myField").isInputField
