Color of function keys
Fre_Vdh
Re: Color of function keys
Post by Fre_Vdh »
I do have another style defined for x29, maybe that's an issue?
Removing the existing "x29" definition might be worth a try.
Fre_Vdh
Post by Fre_Vdh »
I removed the x29 definition, but still the same.
The background of div "text1b22" is not red either, so inherit will not work I guess.
Should there not be a rule for that div?
rood weg.png (171.81 KiB) Viewed 72628 times
It seems "inheritance" setting is applied to the background-color. You might want to check if the container div has any background colors.
Fre_Vdh
Post by Fre_Vdh »
I found something:
  • I removed all the customAutoGUIFkeyStyle stuff.
  • On the AutoGui ruile 'Function Keys' i went into the properties and in the eXtensions style I entered
    var f=FIELD.get5250Attribute("id");
    if (f === "X29"){
        var oStyle = {"background-color":"#d99694"};
    else
        oStyle = "";
    ENV.returnValue = oStyle;
  • Now I have the buttons in color and if I add them to a Button Panel the colors are also there
