SslPort for AXESJSM
RobCol
SslPort for AXESJSM
Post by RobCol »
Hello ,
I need to configure AXESJSM on an SSL secure port, I performed these steps:
1- I have created a certificate in DCM
2- I created a server application called "AXES_APP_ID"
3- I have associated the certificate to the application
4-I modified the configuration file /axesjsm/jsm/instance/system/httpd.xml as follows:
<listen port="5563" interface="*ALL" backlog="256" sslport="5564" sslappid="AXES_APP_ID"
sslprotocol="TLSV1.2" secure="false" store="pki/wwwssl.jks" password="password"
buffersend="-1" bufferreceive="-1" nodelay="false" timeout="5"/>
restarted the AXESJSM subsystem,
but only the port 5563 responds in http and not in https on 5564
thank you for helping me
regards
Re: SslPort for AXESJSM
Hi RobCol,
I've conirmed that AXESJSM is running on SSL/TLS secure connection with a *self-signed* certificate for testing.
1. ===> QSH
2. then execute the following Java keytool command to generate the keystore (/axesjsm/jsm/instance/pki/wwwssl.jks) and the key pairs.
keytool
  -genkeypair
  -alias sslkey
  –keyalg RSA
  -keysize 2048
  -sigalg SHA256withRSA
  -dname "CN=192.168.253.102,OU=aXes Team,O=Fairdinkum,L=Asakusabashi,S=Tokyo,C=JP"
  -ext san=ip:192.168.253.102
  -validity 9999
  -keypass password
  -keystore /axesjsm/jsm/instance/pki/wwwssl.jks
  -storepass password
  -v
3. edit the AXESJSM configuration file (httpd.xml) like the following.
Image 484.png (145.56 KiB) Viewed 22196 times
*If my understanding is correct, AXESJSM allows secure/non-secure port execlusively. So it seems sslport parameter in AXESJSM (v4.2.0) is no longer available.
4. export the certificate file.
keytool
-exportcert
-alias sslkey
-storepass password
-file /axesjsm/jsm/instance/pki/axes.cer
-v
5. install it (axes.cer) into a trusted root CA on your PC.
6. re-start AXESJSM subsystem. If the steps above have been done correctly, the secure connection will be established.
Image 485.png (84.75 KiB) Viewed 22196 times
Hope this helps!
RobCol
Post by RobCol »
Hi Fairdinkum,
Thanks for your help, I ran your commands and got stuck with this error :
keytool -exportcert -alias sslkey -keystore /axesjsm/jsm/instance/pki/wwwssl.
jks -storepass password -file /axesjsm/jsm/instance/pki/axes.cer -v
errore keytool (probabilmente non tradotto): java.io.EOFException
maybe it depends on the java runtime version or maybe permissions I don't know, the keystore was created successfully ...
Thanks again
Hi RobCol,
You can check the key store you made earlier by the following command:
keytool
-keystore "/axesjsm/jsm/instance/pki/wwwssl.jks"
-list
-storepass password
-v
> /home/<USERNAME>/list.txt
If the key pairs and the keystore were generated correctly there should be an lias "sslkey" in list .txt.
RobCol
Post by RobCol »
You are great Fairdinkum!!! :D :D :D
There was an error in the keystore, I redid everything and it generated correctly!
It works !!
Fantastic Thank you so much !!! :lol:
Hi RobCol,
Great news! I'm happy I can help you. :D Thanks.
Hide (from Fairdinkum)
RobCol
Post by RobCol »
hello Fairdinkum,
I ask for your help again, to configure ssl port in a production environment and use a valid certificate, how do the steps to follow change? Do I need to import the certificate into the directory?
Thanks so much !
Hi RobCol,
We just experienced the same situation and have dealt with it. What we did are as follows.
1. Generate a self-certificate in JSM. (Same steps as previously)
2. Create CSR using the self-certicate.
3. Create local CA on IBMi so that generating a signed-certificate to the CSR.
4. Import the signed-certificate into the AXESJSM key store (wwwssl.jks).
*Clients have to install the local CA's certificate into their PC.
*For the production environment, CSR should be sent to "real" CA, and receieve the signed-certificate.
keytool
-genkeypair
-alias sslkey
–keyalg RSA
-keysize 2048
-dname "CN=192.168.253.102,OU=WilComm/aXes Team,O=Fairdinkum,L=Asakusabashi,S=Tokyo,C=JP"
-validity 398
-keypass password
-storepass password
-v
2. Create CSR
keytool
-certreq
-alias sslkey
-keypass password
-storepass password
-file /axesjsm/jsm/instance/pki/server.csr
3. Create a local CA on IBMi and issue the signed-certificate
--->See the attached. (Sorry but it's Japanese edition. Google Lens or other apps will translate for you ;)
Firstly, import the CA certificate into wwwssl.jks
keytool
-import
-file /QOpenSys/QIBM/ProdData/SC1/OpenSSL/demoCA/cacert.x509
-alias demoCA
*-file option specifys the CA certificate file.
Nextly, signed-certificate.
keytool
-import
-file /axesjsm/jsm/instance/pki/server.crt
-alias sslkey
-noprompt
-trustcacerts
*-file option specifys the signed-certificate.
Hope this helps!
SignedCertificateForAxesJSM_20210331a.pdf
(650.3 KiB) Downloaded 928 times
RobCol
Post by RobCol »
Hello Fairdinkum,
I begin to thank you very much for the excellent explanations and for the help! I'll let you know as soon as I try.
I believe I use the translator for the attachment :lol:
Thanks so much
jaimosky
Post by jaimosky »
I did the steps you mention here, but instead I have used Digital Certificate Manager (I did a CA and a Certificate for ldv720 signed with the CA and exported the files).
So I created the jks file
keytool
  -genkeypair
  -alias sslkey
  -keyalg RSA
  -keysize 2048
  -dname "CN=10.90.10.201,OU=eZollOnline,O=LDV Systema,L=Salzburg,S=Salzburg,C=AT"
  -ext san=ip:10.90.10.201
  -validity 9999
  -keypass password
  -storepass password
  -v
then imported the 2 certificates
keytool
-import
-file /ezollat/cert/CACERT_new.cer
-alias CA-LDV720
 keytool
 -import
 -file /ezollat/cert/SERVERCERT_new.cer
 -alias server-LDV720
 -noprompt
 -trustcacerts
I have seen, in the import you detailed in your example you use twice the alias sslkey, but it seems not working unless you modify this alias.
I modify as you say the httpd.xml file and restart the JSM SBS.
So when I call https://ldv720 i get an error, and when I open the certificate I see is extenden to the IP Address. It seems as the server presents not the certificate but the keyEntry(alias sslkey) instead of the trustedCertEntry(alias server-LDV720). I checked with -list the content of the jks file and there are one keyEntry and two trustedCertEntry.
I am sure I am doing something wrong, but I cannot figure out what.
Any ideas?
