aXes - Generically Identify screens
Eugene.King
Post by Eugene.King »
Can aXes use generic screen identifiers?
I have an application with two types of popups, select single entry and select multiple entries. They use screen identifiers of PIDSXX-S, for select single entry popups or PIDSXX-M for select multiple entry popups. The XX is an integer. I want to create a single screen design for each type and have them apply to all popups across the system. Has anyone had any experience of doing this in aXes? Any suggestions welcome.
Thanks in advance.
Eugene
Re: aXes - Generically Identify screens
Hello,
In my opinion, to achieve the goal, the screen definition should be set as follows:
Case 1. If the layouts of the pop-up screens are exactly the same for each type, give the same name (eg PIDS-S, PIDS-M) to all screens of each type.
Case 2. If the pop-up screens' layouts are slightly different for each type (such as field start position), (1) Give the same name (eg PIDS-S, PIDS-M) to all screens of each type, and (2) Specify a different value for Variant Name. (Example: 01, 02, ...)
Jun Kato
