Can convertDynamicTable disable the column line
Hello,
Does anyone know how to disable the column line in use of convertDynamicTable().
Please look at the attached file.
Thanks for your help.
Re: Can convertDynamicTable disable the column line
Hi Hide,
Thanks for your question.
There is not efficient way to achieve what you want to do at the moment.
I suggest you raise this with LANSA Support and we can implement a keyword to do that in the future.
Hope this helps.
Hi JM,
Thanks for your answer. I understand and will raise this to the support team as an enhancement request.
