Hello,
Does anyone know how to disable the column line in use of convertDynamicTable().
Please look at the attached file.
Thanks for your help.
Can convertDynamicTable disable the column line
- Image_20170728_173041001.png (29.19 KiB) Viewed 6092 times
- jeanmichel
Re: Can convertDynamicTable disable the column line
Hi Hide,
Thanks for your question.
There is not efficient way to achieve what you want to do at the moment.
I suggest you raise this with LANSA Support and we can implement a keyword to do that in the future.
Hope this helps.
Hope this helps.
email: [email protected]
Hi JM,
Thanks for your answer. I understand and will raise this to the support team as an enhancement request.
