[axes310] - See the CSS options as a list
Depending on whether you like typing your own CSS attributes (because you know what you are doing) or choose in a list the one you want because you can never remember the exact syntax, there is an option for everyone.
In the application settings, under the heading Styling, property interface, you can choose between List or JSON
  • List will show a table with all the CSS options.
  • JSON will show an editor where you can type the CSS attributes as a JSON structure
