is there any way to load a quick pick via a static table?
gracehsu
Post by gracehsu »
I'm making a custom extension. I CAN load it manually, but we have a table on the system where we add any options we have coded, is there any way to load the option from the table?
Re: is there any way to load a quick pick via a static table?
You can implement the Quick Pick Menu with static or dynamic tables using the following code:
*This is an example using a dynamic table.
(items) *DynamicMode*
var r = [];
var t = "CUSTP"; //動的テーブル名
TABLEMANAGER.loadDynamicTable(
    t,
    USERENV.dynamicTablesFile,
        /*Optional for SQLVariables*/
    false
var q = TABLEMANAGER.getTable(t);
 * itemsプロパティの caption として取得
r.push({"caption": ""});
for ( var i = 0; i < q.childCount(); i ++ ){
    r.push(
            "caption": q.child(i).value + ":" + q.child(i).text
ENV.returnValue = r;
(onItemSelection)
 * ENV.itemNumber... 1, 2, 3, ..., n
 * q.child.......... 0, 1, 2, ..., n
if ( ENV.itemNumber <= 1 ){
    FIELD.setValue("");
}else{
    FIELD.setValue(q.child(ENV.itemNumber-2).value);
HTH.
Hide (from Fairdinkum)
