Date fields
WayneP
Date fields
Post by WayneP »
So I am following the tutorials (#3) and I have added a date extension to the employee date of birth. It looks OK, but now I can type data into the field, but it doesn't stay. It only stays if I use the calendar. So if an employee is 50 years old, am I suppose to page back 50 years in the calendar to get to that date? Is there a way to simply type the date instead of using the calendar?
Re: Date fields
Hi Wayne,
Yes I believe there is. When you click on the field, the date properties will show in the properties detailer on the left.
Check calendarMonthSelect and calendarYearSelect
Like this:
