Combine Dropdown with AutoComplete
Fre_Vdh
Post by Fre_Vdh »
Hello,
Is it possible to combine the Dropdown extension with the Autocomplete?
Or, when doing it with 'Multitype Input Box' extension and Autocomplete extension, is it then possible that the list is shown when pressing the prompter instead of sending the F4 key?
Greetings,
Frederik
Re: Combine Dropdown with AutoComplete
Where we were...
If you have a prompter in the screen the code in it generated automatically by aXes is something like this:
FIELD.set5250Cursor();
AXES.Layout.prevField();
SENDKEY('F4')
So if you add a dropdown to the screen, make it visible false, you could use a code like this:
FIELDS("InputField").setProperty("visible", false);
FIELDS("InputField").refresh();
FIELDS("DropDown").setProperty("visible", true);
FIELDS("DropDown").refresh();
to do something different like for example to make visible a dropdown in the screen and not visible the input field.
and so on. you can make the drop down to update the input field, etc.
