Changed Sign-On screen QDSIGNON and aXes
If you have a customized sign-on screen (a version of QDSIGNON) for your users like the image below, where in aXes can you indicate the current position of the username and password fields, and so on?
bark
Re: Changed Sign-On screen QDSIGNON and aXes
Post by bark »
Hi Dino
I was given the attached instructions years ago. I don't think I ever needed to use it but I assume they cover what needs to be done to correctly customize a logon screen without encountering any issues by messing up the order of the fields.
Cheers
bark
Checking Customized Logon Screen.pdf
(87.2 KiB) Downloaded 701 times
Thank you very much! This helps indeed.
