Trouble with date extensions
Joerg Hamacher
Post by Joerg Hamacher »
we are working on a German IBMi system.
In our 5250 applications date fields are normally edited in format DDMMYY and displayed in format DD.MM.YY
E.g. when opening a 5250 screen the date (input field) is displayed as 12.06.19
In aXes I define this field as date (date extension) - but when I open the screen in aXes no date is displayed in the date field box.
After selecting a date using the calendar a date is shown in the box. After pressing the ENTER-button the date box is empty again and our program triggers the error message that no valid date was entered.
dateFormatDisplay / Edit / Server are "ddmmyy".
What can be done?
Many thanks in advance,
Joerg
Re: Trouble with date extensions
Hi Jorg,
Apologies for the late reply on this one.
In the date format, you need to set the dateFormatServer peoperty on the date extension property to match the format you require (e.g. MM.DD.YY)
Unfortunately we do not have a matching setting as the one you are looking for.
You could request this enhancement to be added by emailing Lansa Support.
Joerg Hamacher
Hi Jean-Michel,
thanks for your reply.
No problem with the time passed - everything's OK! Made me to get creative and to try the settings of date extension property values in between ;-)
I changed dateFormatDisplay and dateFormatServer to ENV.returnValue = "dd.mm.y" and dateFormatEdit to "ddmmyy" and now it works fine.
Cheers,
Joerg
Post by tim mcentee »
Hi Joerg
If you follow the JQuery dateformat documentation there are a lot of formats available that can be set via returnValue='dd.mm.y' etc
https://api.jqueryui.com/datepicker/#utility-formatDate
