Log4J ?
Franck.A
Log4J ?
Post by Franck.A »
Hello All,
I have heard about this "little" issue regarding a vulnerability in Log4j.
As I am more from the IBM's world, I have literraly no clue about what it is but I was wondering if this could affect the Lansa Axes tools/objects.
so here is my question : should I worry ? :)
Thank you for your help.
Re: Log4J ?
Hi Franck,
This has been posted in the lansa forum about it:
https://forum.developer.lansa.com/viewt ... f=3&t=2561
I found a jsmlog4j.jar in the /axes421jsm/jsm/instance/jar folder.
Same way as indicated in that post, you could remove jsmlog4j.jar from "/axes421jsm/jsm/instance/jar" folder (move it to /tmp for example), restart JSM (endsbs axes421jsm/axes421jsm, wait for it to end, then strsbs axes421jsm/axes421jsm) and test aXes application to see if they still work normally.
Franck.A
Re: Log4J ?
Post by Franck.A »
Hi Dino,
Thank you very much for this information, we are going to test the procedure on our preprod environment.
Best regards,
Franck
