Axes commands
eduardorama
Axes commands
Post by eduardorama »
1) Where do I find the documentation of all the axes command?
e.g. SHOWAXESMENUBAR(false); // false = hide, true = show
2) If there's no documentation, what javascript file contains all the definitions?
Re: Axes commands
All documentation are here: https://www.axeslive.com/support/documentation.htm
if you click 4.2.1 in particular you get directed here: https://axesdocs.lansa.com.au/index.php
some detail are here under features: https://axesdocs.lansa.com.au/index.php/feature-help-2
but the extensions or functions listed in that particular way, I cannot find it anywhere, the documentation for this product is oriented to a more lead by example way... if you take a look to the axextensions.js file:
you can get a peek about what extensions are available for aXes.
eduardorama
Re: Axes commands
I used to have the pdf file where all the commands are listed but I can't find them anymore.
But yes, this axextensions.js is what I need.
Thanks!
jtaljaard
Re: Axes commands
Post by jtaljaard »
Where can I locate this file?
