Is there something like this in this new server, or how can I see if the session was started with aXes or not?
# S T A R T O F C O N F I G U R A T I O N #
# aXes TS User configuration file
# Uncomment (remove the #) and alter lines as required
# The list of user attributes:
# user*=enable,device,InlPgm,InlMenu,CurLib,IP mask,view,sessions,devType,kbdType,charset,codepage
# user name supports generic values using wildcards: ?,*
# device name can include the following substitution values:
# $U is replaced by the user's OS/400 user profile name
# $* is replaced by a sequential number
# ip mask supports generic values using wildcards: ?,*,**
# Examples:
# JOE=1,JOE000001,QCMD,SYSTEM,USERLIB,192.10.1.*,noview,1
# JOE is allowed to use aXes sessions
# JOE will also acquire the JOE000001 device and will run
# QCMD as the initial program, the initial menu will be SYSTEM,
# and the current library will be set to USERLIB.
# JOE is required to logon only from the specified IP address range.
# JOE sessions may not be viewed via the Administration interface.
# JOE is restricted to a single session.
# QSECOFR=0
# User QSECOFR may not sign-on to this terminal server instance.
# TST*=1,AXESTS2$*,,,,,,2
# All users with profiles starting with TST are allowed to use aXes sessions
# All users with profiles starting with TST will be assigned devices named AXESTS2...
# All users with profiles starting with TST are limited to 2 sessions
*=1,AXESTS2$*,,,,,,
