Is there any way we can customize the function keys using auto gui show function keys on panel.
Is there a css file that we can customize?
customize function key
- funtion key.png (49.56 KiB) Viewed 9279 times
Safal Piya
Safal Piya
- jeanmichel
Re: customize function key
HI Safal,
You cannot change the design of the button sin the function panel in V4.1.1
You could try and use the button panel which allows you to insert your custom buttons.
email: [email protected]
Hi Jean Michel,
Why the function keys get disappears or half visible through out the pages ?
Safal Piya
Safal Piya
Safal Piya
Safal Piya
- jeanmichel
HI Safal,
This is a support issue and you should be reporting this to LANSA Support together with a fiddler trace. Instructions on how to do this are available here:
viewtopic.php?f=10&t=51
I suspect this had something to do with any of the following:
- Your custom wrapper around the aXes terminal div
- The image in the background
- The terminal div is too large and the overflow is hidden as a consequence of the first point. Note how you cannot see the bottom of the terminal div containing the messages.
