aXes in V7R3 with SSL not being started
Posted: 24 Apr 2018, 01:17
HI,
We have just updated from V7R1 to V7R3 and I wanted to test SSL functionality (we use it in Live Environment)
I have just define a certificate and application, that I include in the configuration file:
SSLOnly=1
SSLPort=443
SSLAppID=AXES_SSL
I have also granted to the AXES user on the folder /QIBM/UserData/ICSS/Cert/Server *RW rights and *R to all of files included there.
(in fact, I have granted also *RWX but it doesn´t seem to work)
But, whenever I started STRAXESW3, I got following error message:
It seems as I am missing something, but I have double check the possible problems.
Anybody has an idea, what else I could change?
Thanks a lot for your support.
Jaime
SSLOnly=1
SSLPort=443
SSLAppID=AXES_SSL
Weitere Nachrichteninformationen
Nachrichten-ID . . . . : AXS5006 Bewertung . . . . . . : 20
Nachrichtenart . . . . : Diagnose
Sendedatum . . . . . . : 23.04.18 Sendezeit . . . . . . : 16:51:40
Nachricht . . . : Could not initialise SSL on port 443.
Cause . . . . . : An error occurred when initialising the Secure Sockets
Layer (SSL) on port number 443 using application identifier AXES_SSL. ERRNO
is 3401. SSL_ERRNO is -10. Message text for ERRNO is: Berechtigung
abgelehnt.
Recovery . . . : Verify that SSL is configured correctly. Possible
problems include:
The application identifier has not been registered, the certificate has
not been associated with the application, the certificate is expired, or the
AXES user is not authorised to the certificate.
See member SSL in QSYSINC/H for the meaning of the SSL_ERRNO. Look for
names of constants containing 'SSL_ERROR_' It seems as I am missing something, but I have double check the possible problems.
Jaime
