aXes Mobile - How to add a button to use the Camera feature
This forum is managed by LANSA and contains documentation update and video tutorials
How to add a button to a project to use the mobile device's Camera feature
1) Open aXes development environment
2) Load your project in TS2 and navigate to the screen you wish to customise
Click on "Work as a TS2 Developer"
Signon to your session
Type on the command line: "addlible axesdemo" followed by enter
Type on the command line: "call xhrrpgtrn" followed by enter
Put an X next to to an employee
If you don't have a screen definition, press suggest and save the screen.
3) Add a PushButton
4) Edit caption. Change the caption value to "Take Photo"
5) Edit script
Copy and paste the script hereunder in the edit box.
Please note you will need to amend the URL of your server as well as the username and the password required to connect.
if (window.LRSV)
var config =
   serverUrl: "http://server.domain.local/service/longreach.jsp",
   credential: {user:"myusername",password:"mypassword}
LONGRANGE.FileTransfer.setDefaultConfig(config);
var options =
   imageName : FIELDS("EmpID").getValue() + ".jpg",
   annotate : true,
   toIFSfolder : "{BASE}/"
try
   LRSV.imageUpload(options);
catch (Error) { alert("problem uploading photo"); }
6) You should now have a button on your screen which looks like this:
7) open aXes mobile and run your demonstration
Image Image Image
