V6R1 CUME C1102610 will cause aXesTS issues
axessupport
Post by axessupport »
aXesTS users on V6R1 have reported that after applying CUME C1102610 you will immediately encounter various TCPIP errors when using the Terminal Sessions.
The messages can vary but quite often users will be faced with longer response times followed by a "400 Bad Request" message or "Attention - The application is Busy. Do you want to continue waiting ?" message.
There are IBM PTFs available to address this issue:
If your LIC is R610 then apply PTF MF53662.
If your LIC is R611 then apply PTF MF53664.
These are immediate PTFs, however be sure that you read and follow the cover letter on what is needed to be done when applying the PTF.
