Checking which version of aXes is installed
axessupport
Post by axessupport »
How to check if aXes has ever been installed on a server
Execute this i5 OS command: DSPLICKEY PRDID('1AX*')
If you see the message "License key information not found" then aXes has never been installed on this server.
How to check the version of aXes installed
The aXes version number can be found on the aXes server’s default page.
Open the URL for you aXes server in a web browser using http://<host address>:<port> e.g. http://www.xyzcompany.com:8080 to display the aXes application server's default page.
Locate the aXes version number at the bottom left.
