How to specify the table name by using variables to output CSV
Posted: 11 Jan 2017, 10:13
by MegumiSawada
The customer would like to output CSV data from the table using selectSQLcommand like Tutorial 6 - Tables and XML Documents.
They would like to specified the table name by using variables ('B'+JOB number).
Is it possible to specify the name of table (which output CSV data from) by using variables?
If Yes, could you please let me kno how?
e.g.
DefineObjectInstance {
className = "DynamicTable",
name = "Example2",
source = "sql",
selectSQLcommand = "EMPNO, SURNAME FROM DCXPGMLIB.<<File name variables>>",
resultColumnNames = { "TEXT1", "TEXT2" },
Re: How to specify the table name by using variables to output CSV
Posted: 13 Jan 2017, 09:45
by jeanmichel
The format is the same as how sql variables are defined in WHERE statement.
Example, in tables_dynamic.txt file define the following:
name = "Example2",
source = "sql",
selectSQLcommand = "EMPNO, SURNAME FROM DCXPGMLIB.:SQLVariableTableName",
In AXES, example, in a button to output CSV, add the following script on its onClick property.
var requestdetails = { SQLVariableTableName:"<<table name>>" };
var result = TABLEMANAGER.convertDynamicTable( "Example2", USERENV.dynamicTablesFile, requestdetails );
if (result.error == false)
var URL = document.location.protocol + "//" + document.location.host + "/ts/" + result.outputFileName;
window.open(URL,"_blank");
For dropdown eXtension set the following property:
sqlVariables: ENV.SQL.SQLVariableTableName = "<<table name>>";
Posted: 19 Jan 2017, 17:37
by MegumiSawada
Hi Jean-Michel,
Thank you for your reply.
The customer has successfully implemented it with your instruction!
