Setting a Global Style in aXes
Posted: 08 Jul 2016, 23:26
by MarcusLancaster
Hi all.
I'm working with TS (as opposed to TS2) and I'd like to create a global style (to set a font-family) which is only applied to ALL INPUT boxes. I can create an Application Level style in the aXes Designer;
stylefor: HTML Element
htmlTAG: .InField INPUT
style: font-family: Verdana
But that only seems to work when the screen is not customised. As soon as I start customising a screen, the style no longer applies.
Is there a way to set a style which is picked up regardless of whether a screen is customised or not? Or is there a way to set a global style for customised screens, then I would only need to define the style twice (once for customised and once for non-customised).
As an aside... the aXes screens will be used within a RAMP environment, so the style should persist into that environment too.
Any help or advice would be gratefully received. If I'm missing something obvious, apologies, its been a while since I last worked in the aXes environment!
Cheers for now.
Marcus.
Re: Setting a Global Style in aXes
Posted: 12 Jul 2016, 10:27
by jeanmichel
Hi Marcus,
This is a bug in TS. Please report this via the LANSA support channels.
Thanks for finding this.
Posted: 15 Aug 2016, 11:17
by jeanmichel
Hi Marcus,
You have this information already. I thought I will port it here for future references.
After further investigation and debugging, this issue can simple be fixed by removing the class in the CSS definition.
Original definition:
The above css will only work on non-customised screen because non-customised screens uses the default axes.css which defines the .InField class for inputs. But once the screen is customised, the axes.css will no longer be used but the defined application_xxx.css.
So instead of the above definition, for customised screens, the following can be used instead:
htmlTAG: INPUT
Just removing the class will apply the style to all inputs.
Posted: 06 Aug 2017, 12:46
by ketut
Hi JM
Beside INPUT what else for htmlTAG?
Posted: 06 Aug 2017, 12:48
by ketut
Hi JM
Beside INPUT what else for htmlTAG? Is the reference just from axes.css?
Best regards
Ketut
Posted: 08 Aug 2017, 15:04
by pius
Hi Ketut.
It will work on any html tag.
Eg. textarea, a, button, etc.
Best regards,
Pius
Posted: 09 Aug 2017, 20:34
by ketut
Hi Pius,
I have an issue about setting global Button Style in aXes.
I made 2 button with different color.
first button style
styleFor: HTML Element
htmlTag: BUTTON
style: { background-color: #4CAF50 ; }
BUTTON:hover
{ background-color: #46a049 ; }
second button style
first button style
htmlTag: BUTTON
style: { background-color: #f44336 ; }
BUTTON:hover
{ background-color: #da190b ; }
When i implement all buttons, only first button style works, but the others doesn't work, even it has style like first style.
Can you help me?
Best regards
Ketut
Posted: 10 Aug 2017, 15:55
by pius
Hi Ketut,
If you are going to create two different styles for the same element, you need to be more specific on the htmlTag.
You can add class names in the htmlTag as well.
Eg.
htmlTag: .success BUTTON
htmlTag: .danger BUTTON
where ".success" and ".danger" are the classes specific to the buttons you want the btnSuccess or btnDanger style to be applied to.
So for btnSuccess to be applied to a button, it must have the "success" class.
Hope this helps.
Best regards,
Pius
