Changing font and font size
Joerg Hamacher
Post by Joerg Hamacher » 31 Oct 2019, 01:30
I need your help because our aXes4.2 IBMi is broken and a customer has problems with fonts and font sizes and I cannot look and try myself....
Green screen (Image1.jpg) shows well placed header and subfile header text lines (the two lines above the subfile and the header line are defined in DDS as one line, not as single fields).
aXes4.2 transforms this lines not correct - as you can see in Image2 - it seems all quite compressed.
How and where can I generally change font and font size to make the transformation correct automatically.
Many thanks in advance - cheers,
Re: Changing font and font size
Post by jeanmichel » 05 Nov 2019, 11:25
You could try and change the font on the TS window, from the display menu, choose use monospace fonts.
Screenshot from 2019-11-05 12-23-55.png (41.08 KiB) Viewed 7521 times
Joerg Hamacher
Post by Joerg Hamacher » 05 Nov 2019, 18:31
Hi Jeanmichel,
that does not work.
Best regards, Joerg
Post by jeanmichel » 06 Nov 2019, 07:07
Another option you can try is:
1) Create a new project to test
2) In developer mode, Go to the screen which does not display properly.
3) Select application in the extendable objects
4) Change autoColWidth to off. A dialog dhow up asking if you want to keep or reset. Choose reset.
5) Choose "use monospace Font" in the display menu item
5) Save and reload your project
Everything will be lined up
Before :
Screenshot from 2019-11-06 10-01-17.png (13.79 KiB) Viewed 7503 times
After
Screenshot from 2019-11-06 10-01-33.png (15.08 KiB) Viewed 7503 times
bark
Post by bark » 06 Nov 2019, 08:02
If this was not happening in an older version of aXes and has only started to happen after moving to 4.2.0, I think you should send to support as an introduced problem.
cheers
bark
