customize function key
safalpiya
Post by safalpiya » 02 Nov 2018, 05:00
Is there any way we can customize the function keys using auto gui show function keys on panel.
Is there a css file that we can customize?
funtion key.png (49.56 KiB) Viewed 106 times
Re: customize function key
Post by jeanmichel » 23 Nov 2018, 08:45
HI Safal,
You cannot change the design of the button sin the function panel in V4.1.1
You could try and use the button panel which allows you to insert your custom buttons.
safalpiya
Post by safalpiya » 08 Dec 2018, 06:41
Hi Jean Michel,
Why the function keys get disappears or half visible through out the pages ?
function key.png (1.19 MiB) Viewed 72 times
Safal Piya
Post by jeanmichel » 13 Dec 2018, 10:53
HI Safal,
This is a support issue and you should be reporting this to LANSA Support together with a fiddler trace. Instructions on how to do this are available here:
viewtopic.php?f=10&t=51
I suspect this had something to do with any of the following:
- Your custom wrapper around the aXes terminal div
- The image in the background
- The terminal div is too large and the overflow is hidden as a consequence of the first point. Note how you cannot see the bottom of the terminal div containing the messages.
