Hi, it´s me again.
After looking in internet I have figure out, what the problem is. In order to be able to use a signed certificate in the jks file, I should generate the CSR with it, and leave it sign by a CA. Then import both, the CA and the signed certifiace and then should work.
But my question is, it is possible to use a certificate already existing in the system?
So i think the problem should be solved if instead of a jks file I could use the /QIBM/UserData/ICSS/Cert/Server/DEFAULT.KDB. So I could use both servers W3 and JSM with SSL.
Does anybody know how to do this?
Jaime
----------------------- Update ------------------------------------------
I have found a way to Export the .kdb file where the certificates are with the IBM Key Manegement. I first imported the .kdb file and then exported als .jks file, so it can be used with the JSM Server.
SslPort for AXESJSM
