Color of function keys
Re: Color of function keys
That's weird.
Can you check if the class "ax_customeautoguifkey" is there in a container DIV like shown below.
Image 023.png (216.28 KiB) Viewed 140406 times
Note: if top and height are removed, it appears like above. The container DIV height is bit larger than the button.
If it exists there, the CSS selector "div.ax_customeautoguifkey button" should work.
Image 024.png (181.86 KiB) Viewed 140406 times
Fre_Vdh
Post by Fre_Vdh »
No it's not... we are using Material Design, I don't know if it has to do something with that?
Oh I see, you used the fKey panel extension. That's the difference between you and myself. I will try using the fKey panel as well tomorrow. Or it will work once the fKey panel is removed, I presume.
If it's "normal" autoGui button, it has a class linked to DSPATR. In case as shown below, "x29" represents COLOR(RED) DSPATR(RI).
Image 025.png (140.76 KiB) Viewed 140388 times
COLOR(RED) + DSPATR(RI)
Image 027.png (10.01 KiB) Viewed 140388 times
On the other hand, fKeys in fKey panel don't have the information about DSPATR...
Image 026.png (146.92 KiB) Viewed 140388 times
So I think there are two options.
1. use "normal" autoGui fKey button.
2. ask Lansa to enhance this portion.
Fre_Vdh
Post by Fre_Vdh »
Thanks for investigating this, but the result is as we thought.
It's impossible to start changing all the screens that have been made so far, so I guess we'll have to wait on Lansa to make this.
Unless it's possible to change the fKeyPanels to "normal" autoGui buttons in one action?
Kind regards,
Frederik
Try unchecking "Show function keys on Panel.
Image 033.png (26.5 KiB) Viewed 140383 times
Fre_Vdh
Post by Fre_Vdh »
The screens that haven't been edited yet now show the function keys on the screen itself, and in a function key panel (that's automatically added apparently).
On the existing screens I only see the function key panel.
Oh I see. It happens here too. Orz
Found a solution.
Image 035.png (135.14 KiB) Viewed 140380 times
Fre_Vdh
Post by Fre_Vdh »
I would have to do that on every screen then...
But I'm giving it a try for this screen to see what happens, maybe something can be found so that it can be a bit automised.
The div around the button ("supp") now gets the ax_customeautoguifkey class, but the style is not taken over. If you look at the right box, you see that the css is also shown. I tried changing the 'inherit' to #F12345 and then all the buttons got a color.
