Color of function keys
Fre_Vdh
Post by Fre_Vdh »
Hello,
In our greenscreens we have function keys that are by default with a green background, but when there's data that will be shown when clicking them, they are red.
Is it possible to have the same style in aXes?
Kind regards,
Frederik
Fre_Vdh
Re: Color of function keys
Post by Fre_Vdh »
Just had a quick meeting with Lansa in which was said that it may be possible to do this via a Global Rule that changes every function key panel to a buttonpanel and that way we could get the hex-code of the buttons and use that color.
The person that said this, did not exactly know how to do this, but he suggested to put it on the forum and maybe some clever person would know a solution.
All my hope is on you guys :D
Kind regards,
Frederik
Hi Frederik,
I might be able to do that. Can you share the screenshots for my better understanding?
Hide from Fairdinkum
Fre_Vdh
Post by Fre_Vdh »
This is the policy screen where you can see that 5 function keys are red:
Polis - green screen.png (25.05 KiB) Viewed 303670 times
When you click on F24=doc, a window opens and there you can see that one function key is red:
Documenten - green screen.png (10.78 KiB) Viewed 303670 times
The lay-out in aXes from the policy screen is:
Polis - aXes.png (64.94 KiB) Viewed 303670 times
We would like the same function keys to be in a different color (red).
This is the aXes screen when you click F24=doc:
Documenten - aXes.png (37.07 KiB) Viewed 303670 times
Kind regards,
Frederik
Hi Frederik,
Can you try this when you have time?
(1) add the following code into autoGuiFkey's basic style.
_base: customeautoguifkey;
---> ax_customeautoguifkey class will be added into a container DIV of autoGuiFkeys.
(2) set "outlined" to autoGuiFkey's buttonStyle.
(3) add the following Application.style.
name... e.g. customAutoGUIFkeyStyle
styleFor... html
htmlTag... dummy, div.ax_customeautoguifkey button
style... {top: -1px !important;height: 18px !important;background-color: inherit !important;}
*top and height settings are just for its look and feel. So you can try without those css first.
I got the following results.
Image 015.png (9.68 KiB) Viewed 303823 times
Image 021.png (9.12 KiB) Viewed 303823 times
Hope this helps.
Fre_Vdh
Post by Fre_Vdh »
(1) Is that here? I get the yellow triangle there...
1 (1).png (78.15 KiB) Viewed 303668 times
(2) ok
(3) I can't type it all after each other, is it good like this?
2 (1).png (43.38 KiB) Viewed 303668 times
(1) should be inside {}.
(3) if still not working, change the interface property in Application.Style to json.
Fre_Vdh
Post by Fre_Vdh »
(1) is still with the triangle:
1 (2).png (113.47 KiB) Viewed 303663 times
(3) it worked to insert with changing to json.
Try this:
Image 022.png (294.54 KiB) Viewed 303817 times
Fre_Vdh
Post by Fre_Vdh »
Now I could fill it in, but it's still all blue keys.
The styles is correctly filled in? I tried leaving out the top and height like you suggested.
