When a user selects a date field, some suggestions are made.
The dateFormatEdit for the fields is ddmmyyyy, but the suggestions are dd/mm/yyyy. The dateFormatDisplay and dateFormatServer are both dd/mm/yyyy.
When a user clicks on the suggestion, it's inserted into the field. But if the user hits 'enter', the field is being blanked out again.
Is it possible to turn off suggestions in all the fields in aXes?
Kind regards,
Frederik
(Date) suggestions
Theo de Bruin
Re: (Date) suggestions
You can change this for the whole application in the AutoGui Rules of the Date Properties.
Click on the Hamburger Menu (left top) , choose AutoGui , Set Rules button,then
in the Edit Rule window, go to the line with the Date, and click on the Edit in the Properties column,
scroll down to the DateFormatDisplay and change the settings.
