Authentication token tampering on V7R3M0
We are in trouble after applying the latest PTFs to V7R3M0 box. After that, file-uploading (using longreach service) and WS/DE was no longer available. As you can see from the following screenshots, "Authentication token tampering" appears in the error message.
When attempting uploaing a local file to IFS using longreach service.
image (8).png (110.98 KiB) Viewed 17676 times
When attemping signing onto to WS. (It happens to DE as well.)
image (9).png (101.59 KiB) Viewed 17676 times
All the PTFs were correctly applied. (I've asked about it to IBM Japan and still keeping in touch with them.)
Have anyone experienced/dealt this problem?? Need your help! m(__)m
Re: Authentication token tampering on V7R3M0
Here is an update. We've found a couple of PTFs which might cause the problem.
Those are:
- SI75782 5770JV1 V7R3M0
- SI75739 5770JV1 V7R3M0
Removing the individual PTFs shown above after applying the latest PTFs, Longreach/WS/DE were available. (It's a temporary workaround though.)
I'm still working on this...
Me again,
One more thing.
I've tested the followings, but remained unchanged unfortunately...
1) Apply the latest PTFs to V7R3M0.
2) then apply individual PTFs (SI76321, SI76357; these are related to SI75739 which I posted earlier).
MelanieJ
Post by MelanieJ »
Hello,
I am facing the same issue when moving my AS400 to version V7R4.
I have no PTF to cancel..
Do you have news about this issue ?
Many thanks for your kind help.
Mélanie
Hi Mélanie,
I encountered the same yesterday at a client's V7R4M0 box. Fortunately they didn't implement the uploading functionality in their production, though, I think it should be investigated as priority in Lansa. The PTF level of Java (SF99665) was as follows.
5770SS1 V7R4M0  190621        XXXXXXXX  21/09/01  10:40:07 JST
                                                        PTF グループの表示
 PTF グループ . . . . . . . :   SF99665
 レベル . . . . . . . . . . :   10
 状況 . . . . . . . . . . . :    導入済み
 ターゲット・リリース . . . :   V7R4M0
 テキスト  . . . . :   JAVA
        PTF
          プロダクト        保管                        ロード   PTF
 PTF ID   ID       リリース        状況                                        IPL  処置    ファイル       カバー・レター  オプション  ID     レベル
 SI75787  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        0017    5117
 SI75783  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        0016    5116
 SI75742  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        0017    5117
 SI75741  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        0016    5116
 SI75296  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        *BASE   5050
 SI75151  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        0017    5117
 SI75146  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        0016    5116
 SI74988  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        *BASE   5050
 SI73864  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        *BASE   5050
 SI71363  5770JV1  V7R4M0      永久的に適用                                 なし        NO         NO        0016    5116
 SI71361  5770JV1  V7R4M0      永久的に適用                                 なし        NO         NO        0017    5117
 SI70405  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        0016    5116
 SI69708  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        *BASE   5050
 SI69674  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        *BASE   5050
 SI69581  5770JV1  V7R4M0      一時的に適用                                 なし        NO         NO        *BASE   5050
 SI75437  5770SS1  V7R4M0      一時的に適用                                 なし        NO         NO        0003    5050
 SI75188  5770SS1  V7R4M0      一時的に適用                                 なし        NO         NO        0033    5111
 SI74683  5770SS1  V7R4M0      一時的に適用                                 なし        NO         NO        0033    5111
 SI74657  5770SS1  V7R4M0      一時的に適用                                 なし        NO         NO        0034    5050
 SI74561  5770SS1  V7R4M0      一時的に適用                                 なし        NO         NO        *BASE   5050   L00-L00
 SI72224  5770SS1  V7R4M0      一時的に適用                                 なし        NO         NO        0033    5111
 SI72051  5770SS1  V7R4M0      一時的に適用                                 なし        NO         NO        *BASE   5050   L00-L00
 SI69781  5770SS1  V7R4M0      一時的に適用                                 なし        NO         NO        0033    2930
 MF67917  5770999  V7R4M0      一時的に適用                                 なし        NO         NO        *BASE   5050   L00-L00
 MF67139  5770999  V7R4M0      一時的に適用                                 なし        NO         NO        *BASE   5050   L00-L00
 MF66423  5770999  V7R4M0      永久的に適用                                 なし        NO         NO        *BASE   5050   L00-L00
 MF65746  5770999  V7R4M0      永久的に適用                                 なし        NO         NO        *BASE   5050   L00-L00
                                        * * * * *   リ ス ト の 終 わ り   * * * * *
MelanieJ
Post by MelanieJ »
Thank you Hide, your PTFs looks like mine.
IBM has provided us the correspondence of PTFs from V7R3M0 to V7R4M0.
The SI75782 & SI75739 are named SI76356 & SI76324 in V7R4M0.
We have not these PTFs installed in our AS400 but we still have the issue when trying to upload files :
{"type":"error","message":"Exception de service LongReach : Authentication token tampering","sversion":"1.2.1"}
Many thanks in case you have any idea...
Mélanie
Hi Mélanie,
It seems we are now on the same page. We've also checked the following site and learned the correspondence as you mentioned.
https://www.ibm.com/support/pages/740-v ... ce-summary
In my testing, removing SI75782 & SI75739 from V7R3M0 seemed to be a "temporary" solution. And it indicated that SI76356 & SI76324 should be removed from V7R4M0. But unfortunately it doesn't go well on V7R4M0 box...
I've reported to the support team, and have asked that push this issue with more urgency.
MelanieJ
Post by MelanieJ »
Yes indeed, it is urgent for us too.
I got a patch of this and confirmed it works as expected after applying the patch in house. At this moment, it seems it is for v4.2.0.001.
- File uploading... OK
- WS sign on....... OK
- DE sign on........ OK
Thank you Lansa!!
MelanieJ
Post by MelanieJ »
Thank you. I will try too.
