Transparent pop up window
[email protected]
5250 pop up windows are transparent so the screen behind is visible. I have tried a few things to correct this with no success
- Capture.PNG (44.63 KiB) Viewed 32206 times
Re: Transparent pop up window
Hi Nic
Have you tried the popup settings on the url: &popups=n
0 – Off all enhanced window handling.
1 – Turns on the detection of degraded DDS windows only.
2 – Turns on the “keep the previous screen background”
behaviour only.
3 – Turns on both
behaviour only.
3 – Turns on both
Hi Nic,
I've experienced the same before. As far as I know, it happens:
- in 4.1.x.
- the project should be created in 3.1.x.
And what I do as a workaround is:
Step 1) Check useJQueryExtensions and save Step 2) And then uncheck it and save
Step 3) Lastly clear the cache and test
I presume that projectThemes folder (and all the objects in the folder) are necessary in the project folder so that pop up windows appear correctly in 4.1.x. After Step 1 above, projectThemes folder is created in the project folder.
Hope this helps.
- in 4.1.x.
Hope this helps.
Taku Izumi
Hi All,
I found the same issue post in a previous version.
Is there a way to fix the same issue in v4.2.1?
Preferably I can fix this while keeping the style Basic.
Add the following Application.style to your project.
Or modifying /ts/ts2/css/*.css files as follows:
Hide from Fairdinkum
name...... optional (e.g., windowStyle)
styleFor... HTML Element
htmlTag... dummy, div.ax-terminal-window
style....... {
border: 1px solid #c9c9c9;
background-color: #fff;
