Trace and Tracelevel
jaimosky
Post by jaimosky »
I have got a question about protocol and the different levels to be protocoled.
In the config file aXesW3.conf you can use these 2 options to do this:
# Uncomment the following directive to enable the Trace Log
# Note that if you do this the "LogPath" must be specified
Trace=1
# Specify required Log Level
# Tracelevel=Warn Error Info Debug
Tracelevel=Error
But when I open the log file, I can see that the server is protocoling all the levels.
01/Feb/2018 21:51:05 (notice)   Handle send: add read fd
01/Feb/2018 21:51:05 (notice)   =======================================
01/Feb/2018 21:51:05 (notice)   Select 120000
01/Feb/2018 21:51:05 (notice)   Number ready 1
01/Feb/2018 21:51:05 (notice)   Get client data 0 of 1
01/Feb/2018 21:51:05 (notice)   Handle request
01/Feb/2018 21:51:05 (notice)   State FR_RECV
01/Feb/2018 21:51:05 (notice)   Illegal fd or (exitstatus set or redirect) and no header
01/Feb/2018 21:51:05 (notice)   Notify W3 and end connection
01/Feb/2018 21:51:05 (notice)   Handle close: delete fd
01/Feb/2018 21:51:05 (notice)   Select 3600000
01/Feb/2018 21:51:38 (error)    SSLHandshake failure ret=-23 0 There is no error.
01/Feb/2018 21:51:38 (notice)   Number ready 1
01/Feb/2018 21:51:38 (notice)   Get client data 0 of 1
01/Feb/2018 21:51:38 (notice)   Handle pipe
01/Feb/2018 21:51:38 (notice)   Handle pipe: entry
01/Feb/2018 21:51:38 (notice)   Add write fd send
01/Feb/2018 21:51:38 (notice)   Handle pipe: return 1
Is this normal?
Re: Trace and Tracelevel
HI Jaime,
Thanks for spotting this, please raise this as an issue with LANSA support.
