lua script serving pdf files
Posted: 20 Feb 2018, 17:41
by jaimosky
We want to develop so kind of script in lua that would serve pdfs from the IBM i.
The way to use it is:
In the aXes mask we placed a push button and in onclick event we call a program in the IBM that prepares a hash and at the end of the onclick event we call a lua script with this hash.
The lua script looks something like this
Here is the code that we are testing
function trim (s)
      return (string.gsub(s, "^%s*(.-)%s*$", "%1"));
end
local querystring = agi.QUERY_STRING
local URLnf = "<html><head><script type='text/javascript'>window.location = '/pdfnf.html'</script></html>";
if string.find(querystring,"IK") == nil then
	reply("Content-type: text/html\n\n");
        reply(URLnf);
else
	local QSIK = "IK=";
	local IK = string.gsub(querystring,QSIK,"");
	local pgminterface = os400.pgm
	local parmDefinitions = {  };
    	local parmValues      = {  };
    	parmdefinition = pgminterface.char400(255);
	table.insert(parmDefinitions,parmdefinition);
	table.insert(parmValues,IK);
    	parmdefinition = pgminterface.char400(100);
	table.insert(parmValues," ");
    	retcode, err = pgminterface.call("PRODLIB/PGM00345", parmDefinitions, parmValues);
	if string.find(querystring,"IK") ~= nil then
		local path2 = string.lower(trim(parmValues[2]))
		local ending = ".pdf"
		if string.find(path2,ending) ~= nil then
			local inp = io.open(path2, "rb");
			local data = inp:read("*all");
			reply("Content-type:application/pdf\nContent-Disposition: inline; filename=\"download.pdf\"\n\n");
			reply(data);
		else
			reply(URLnf);
		end
	else
	        reply(URLnf);
	end
end
The problem is that we do not get the header Content-Disposition, so the webbrowser receives the stream but doesn´t know what to do with it. Well, if you associate the .lua with pdf viewer then it works, but we would like to do it without this association.
Do you think is this possible?
