aXes / Longreach - other folders than longreachdata
Joerg Hamacher
Post by Joerg Hamacher » 29 Apr 2020, 02:15
Hi again,
when displaying images or PDFs in aXes42 we have to use longreach.
This works fine as long as I am using IFS folders longreachdata or longreachdata_public.
Now I tried to use another IFS folder that contains special PDFs. Name of this folder is SMH_Inventurbogen, it is created directly under the root folder.
Then I changed httpd.xml like this:
LongReach
Public users
<parameter name="service.folder.public.get.allow" value="/longreachdata-public/other/"/>
<parameter name="service.folder.public.get.allow" value="/longreachdata-public/other/*"/>
<parameter name="service.folder.public.get.allow" value="/SMH-Inventurbogen/"/>
<parameter name="service.folder.public.get.allow" value="/SMH-Inventurbogen/*"/>
All non-public users
<parameter name="service.folder.get.allow" value="/longreachdata-public/other/"/>
<parameter name="service.folder.get.allow" value="/longreachdata-public/other/*"/>
Subsystems were restarted - user authorities of folder and files are completely the same as of longreachdata or longreachdata_public:
*PUBLIC *RWX X X X X
AXES *RWX X X X X
AXES_GROUP *RWX X X X X
QDIRSRV *R
But when putting this into a hyperlink or button onClick script like
var url = USERENV.createGETURL("http://192.168.0.4:8063/service/longreach.jsp" , "USER", "PASSWORD", "/SMH-Inventurbogen/", "Inventurbogen_MA1_FI00_2016-10-18_110520.PDF");
window.open(url);
the browser says:
response
type "error"
message "Path access denied: /SMH-Inventurbogen"
sversion "1.2.1"
Why? Did I forget anything?
Is it impossible to use folders other than longreachdata or longreachdata_public? How can I get access to folder SMH_Inventurbogen from inside aXes?
Many thanks in advance,
Re: aXes / Longreach - other folders than longreachdata
Post by jeanmichel » 29 Apr 2020, 16:47
Hi Jorg,
You have 2x service.folder.public.get.allow where it should be service.folder.get.allow.
See red corrected below.
LongReach
Public users
<parameter name="service.folder.get.allow" value="/SMH-Inventurbogen/"/>
<parameter name="service.folder.get.allow" value="/SMH-Inventurbogen/*"/>
I don't think you can use your own hand written function to get the file, as there is more than just a get happening. Also it's a POST.
I strongly recommend to use the lui-connector-min.js as in my example:
For example in a HTML page.
<script type="text/javascript" src="/ws/lui-encrypt-min.js"></script>
<script type="text/javascript" src="/ws/lui-connector-min.js"></script>
var m_host = { endpoint:"/service/longreach.jsp", profile:"jeanmichel", password:"xxx" } ;
function callback ( response, fileData )
blabla... }
LUICONNECTOR.getFile ( m_host, { path:"/smhbase/docs", name:"MyPDF.pdf" }, callback ) ;
Joerg Hamacher
Post by Joerg Hamacher » 29 Apr 2020, 19:11
Hi Jean-Michel,
thank you for this - 4 eyes see more than 2! Or I need new glasses ;-)
I use these scripts:
in Application onSignOn the lui-functions are defined:
if ( typeof LUICONNECTOR === "undefined" ) {
$.getScript ( USERENV.protocol + "//" + USERENV.ip + ":" + USERENV.jsmPort + "/ws/lui-connector-min.js" )
.done( console.log("lui-connector-min.js loaded.") );
if ( typeof LUIENCRYPT === "undefined" ) {
$.getScript ( USERENV.protocol + "//" + USERENV.ip + ":" + USERENV.jsmPort + "/ws/lui-encrypt-min.js" )
.done( console.log("lui-encrypt-min.js loaded.") );
... and in USERENV this is what createGETURL does:
createGETURL : function(endpoint, profile, password, path, name)
try
1. Endpoint is needed to get the LongReach server nonce and RSA public key
// Using synchronous mode to create the URL
var response = LUICONNECTOR.createGetFileRequest ( {profile:profile,password:password,endpoint:endpoint,cacheage:0},{path:path,name:name} ) ;
if ( response.type === "error" )
throw response.message ;
2. Endpoint is needed to send the encrypted request to the LongReach server to get the file
return endpoint + "?REQUEST=" + encodeURIComponent ( JSON.stringify ( response ) ) ;
catch ( e )
alert ( "createGETURL exception: " + e ) ;
This is a function we use since some years when this longreach request was integrated into aXes. Is it still okay to use this or should we change anything?
Best regards,
Post by jeanmichel » 01 May 2020, 12:35
HI Jorg,
If it works then all good.
I think we have enhanced this since you implemented this and it's much more simple. All your createGETURL code can be replaced by 2 lines:
try
var m_host = { endpoint:endpoint, profile:profile, password:password } ;
LUICONNECTOR.getFile ( m_host, { path:path, name:name }, callback ) ;
catch ( e )
Joerg Hamacher
Post by Joerg Hamacher » 04 May 2020, 18:50
Thank you very much, Jean-Michel
I will try this and replace my old code with the new one.
Best regards,
