copy/paste
safalpiya
copy/paste
Post by safalpiya » 06 Aug 2019, 00:33
We are not able to do copy and paste function in axes in input field . Is there any way we can use the copy and paste function?
I tried to use Ctrl + C, but when I press Ctrl button, it acts as a Tab button.
Safal Piya
Re: copy/paste
Post by Fairdinkum » 07 Aug 2019, 15:13
Hi Safalpiya,
In our case, we usually advise our customers to change the keymap files (such as as400keymap.xml, defaultkeymap.xml and windowskyemap.xml) they use something like the following:
BEFORE:
<MAP>
  <KEY>Ctrl</KEY>
  <DESC>FIELD EXIT</DESC>
  <COMMAND>FieldExit</COMMAND>
</MAP>
AFTER:
<MAP>
  <KEY>Shift + Ctrl</KEY>
</MAP>
or disable FieldExit key mapping.
<MAP>
  <KEY>Ctrl</KEY>
  <COMMAND>Noop</COMMAND>
</MAP>
HTH.
