aXes Versions Changelog.
This Forum is managed by LANSA and only authorised personnel can post to this Forum.
Post by jeanmichel » 28 Nov 2018, 10:37
aXes 4.2.0.000
149036
This issue has been resolved and the documentation has been updated to specify that TSExpiryTime cannot be set to '0' and should be a value > 0.
156707
An enhancement has been added which allows Special Field Handling properties to be applied to any screen.
157183
An enhancement has been added to allow mouse right click to copy and paste.
157315
An issue has been fixed where the line 23 was not displayed correctly when the screen contains a Scrollable Subfile Table.
159392
An issue has been fixed where the position of an element was reset to its original position when using the method SetProperty.
157574
An enhancement has been implemented to add the events onSelectedValueChanged and onSelectValue to the AutoComplete extension.
157860
An enhancement has been added to allow aXes Terminal sessions to be launched directly by using an URL Scheme in the aXes Mobile App.
157937
An issue has been fixed where theme 5250 cascading style sheet file was referencing the wrong colour code.
157971
An issue has been fixed to prevent the cursor moving 2 lines or 2 columns at a time when the arrows keys are pressed, when the option LimitedCursorSupport is turned on.
158424
A Panel eXtension has been added. It allows users to create a container and add items into it.
158450
A Datatable eXtension has been added. It allows users to render subfiles using the Datatables plugin.
158575
An issue has been fixed where the vertical position of the Spool File was incorrect when used with a WDWTITLE keyword.
158699
An enhancement has been added to allow DBCS to be displayed in the resultColumnCaptions property when using database tables.
158818
An issue has been fixed where characters did not fit in input boxes, with the autoColumnWidth property turned on.
159281
An issue has been fixed where the Top Bar was not displaying after the screen has been customised.
159453
An issue has been fixed where the eXtension Raw element was not implementing the Tab Index properly.
159542
An issue has been fixed where the AutoGUI+ prompt button was not displayed correctly in the Chrome browser when located on a popup.
159621
An issue has been fixed where debug statements were traced out when trace level was set to error. When set to trace level error, only error message should be outputted to the trace file.
159848
An issue with the Quick Pick Menu has been fixed where it does not display properly when setting Above or Right in the property containerLocation.
159897
An issue has been fixed where input fields would be padded with spaces when the option ReplaceNullWithSpaces is turned on.
160192
An enhancement has been implemented which allows the user to add a fixed width value to the size of the input fields. This is especially helpful for very small fields, typically 1 character width, when X is too large to fit in.
160387
An enhancement has been added to allow users to generate a project report which will output all customisation, settings and code added to a project, in a CSV format. This option is available in the aXes Homepage, on the project list, in the developers Tools, via the actions drop down.
160478
An enhancement has been added which allows users to design and publish Material Design themes directly to any project, in a wizard-like environment. This feature is available in the developer tools.
161033
An enhancement has been added to enable the checkbox to be displayed with a classic look when rendered with jQuery.
161037
An issue has been resolved where the copy and paste with special characters caused an abend of the server with the message AXS8205 – Posted data mismatch error. These special characters are now escaped.
161049
An issue has been fixed where the NumMinus character was removed from the input field’s value when pressing the FieldExit key.
161126
An enhancement has been added which allows the values of the dropdown eXtension to be left padded when the option trimValue is unchecked.
161127
An issue has been resolved where the SSO Service was not able to run when the tracing was turned off. The trace object was not protected with an if null condition test, so a NullPointer exception occurred when tracing was off.
161158
An issue has been fixed where the Page Up/Down keys were not being handled properly on mobile devices.
161344
An enhancement has been added to allow all null values on the server to be displayed as spaces on the client when the option ReplaceNullWithSpaces is turned on.
161388
An enhancement has been added to allow users to differentiate between the Enter key and the keypad Enter key in the Keyboard Maps panel.
161408
An enhancement has been added to allow a keymap to be passed into RAMP using the startup URL.
161465
An issue has been resolved where screen elements hidden in aXes 3.1.1 became visible when running on aXes 4.1.0.
161552
An enhancement has been added to aXes Mobile allowing Pinch-In/Out to be available on Android. Pinch-In/Out is already available on iOS.
161700
An issue has been fixed where the screen did not post data when other keys were mapped to the ENTER command for the Date Picker eXtension.
162068
An issue has been fixed where fields with EDTMSK keyword did not show the “/” character properly when PageUp/Down key is pressed.
Re: aXes Versions Changelog.
Post by jeanmichel » 20 Jun 2019, 16:39
aXes 4.1.1.000
158698
An enhancement has been implemented to allow the header to be removed when using the convertDynamicTable() function.
159433
An issue has been fixed where the cursor was not able to move out of the dropdown after the onSelectValueChanged event had been triggered. This issue was caused by the focus being lost by the element after the dropdown value had been changed.
159495
An issue was fixed causing the cursor to be positioned at the last record instead of the first record after applying a Scrollable subfile table to a subfile.
159507
An issue was fixed causing screen styling issues when a popup had been customized.
159660
An issue has been fixed where incorrect data was copied to a field when using Japanese Romaji characters input.
159691
Fixed an issue with screens using 5250 DDS rules lines causing the fields located at the top left corner not being displayed.
159705
Fixed an issue with the install package causing the product install to fail due to a different IBMi *PRIMARY language code.
160026
Fixed a user permission issue causing a user profile with SPCAUT(*NONE) to not being able to read spooled files in CSF mode.
160061
Fixed an issue with the subfile enhancer eXtension when the DDS keyword WDWTITLE is present.
160115
An issue has been fixed where a customer script woudl not execute more than once after the screen onArrive even had been triggered.
160121
Fixed an issue where the AutoGUI+ engine was not recognizing menu items correctly when the next item is not a text field.
160173
Fixed an issue with SpoolFile Manager where spool files with overlapping fields did not display correctly.
160272
Fixed an issue where the displayText property was not fully implemented as part of the autogui+ menu item rule.
160410
Fixed issue with Mutitype Input box becoming blank when content is changed programmatically.
160447
Fixed an issue where the background customization are lost when the popup window is changed.
160465
Fixed an issue with the Multitype input box not being able to retrieve the original field value under certain conditions.
160467
Fixed a security issue where SQL parameters were passed vis URL parameters. This has been changed to POST where the parameters can be encrypted.
160526
Various enhancements and fixes to support the VLF EPC142011.
160533
Fixed an issue with Field Exit key causing input field to be blanked out.
160580
Enhanced the Function Key Panel eXtension to add an option to display function key panel even without any function keys on the screen.
aXes 4.1.0.002
153392
An issue has been fixed where type O fields of length 16 and greater did not get recognised when customising a screen.
154424
An issue has been fixed which was causing the fields with underlines (DSPATR(UL)) on numeric subfiles to be formatted incorrectly.
155550
Fixed an issue where the cursor position was incorrectly calculated using IE11 in TS1.
155717
Added a property on the Window eXtension to change the title of popup.
156017
Fixed a problem with popup windows appearing blank.
156050
Fixed an issue preventing the user from setting the mode of the property Styles to script mode.
156052
Fixed an issue with the admin view cause aXes to end in error on the client.
156161
Fixes an issue where the firstElementToFocus property of the Screen Window extension was not selecting the correct element.
156163
Fixed issue where incorrect values were returned when the subfile index was equal to 1 or 2.
156450
Fixed an issue where the program was not able to end normally and go back to the main menu.
158100
Fixed an issue where the screen background of the terminal window was not being refreshed.
158308
Fixed issues where messages on the status bar were not translated to Japanese.
158347
Fixed an issue with the NewLine key emulation behaving incorrectly after upgrade.
158360
Enhanced ConnectorJS to the latest version.
158376
Fixed an issue where the keyboard properties were flying in an out of the screen when pression Ctrl + Arrow.
158478
Fixed an issue where fields of length 11 to 16 bytes were not using the correct padding character.
158599
An issue has been fixed where AutoGUI+ rule of Page Keys was not detecting text other than "+" or "More".
158636
Fixed an issue in the function keys where the message was overlapping the function keys buttons in TS.
158743
Fixed issue with menu items not displaying properly when using AutoGUI.
158751
Fixed an issue where menu items were not displaying properly when previous field is hidden
158864
Fixed an issue where users were not able to recover previous interactive jobs.
158877
Fixed an issue where output fields would display an invalid character.
158937
Fixed issue with 5250 input fields with DSPATR(ND) not being displayed.
159028
Fixed issue with subfile scroller detection in AutoGUI+.
159036
Fixed issues with subfile context menu detection.
159096
Fixed an issue where a subfile would display additional columns of data thus causing it to appear smaller in some cases.
159137
Fixed an issue where a popup using CLRL(*NO) would cause the screen to show incorrect characters
159165
Fixed an issue where the Function Key Panel disappearing after customizing the screen.
159184
Fixed an issue where the property alternateColors of Subfile Enhancer was not working in User mode.
159188
Fixed an issue where SQL commands would cause AXES server to abend
159208
Enhanced AutoGUI+ to allow users to add notes to a rule.
159259
Fixed an issue where incorrect characters would be displayed when 'WDWBORDER' is used in DDS
159274
Enhanced the eXtension Scrollable Subfile Table to implement the following properties:
  1. headerHeightRows
  2. bodyFirstRow
  3. bodyLastRow
  4. linesPerRow
159312
Fixed an issue where the user had to press the tab key twice before the cursor moves to the next field.
159359
Fixed issue with subfile header AutoGUI detection causing input fields to not update its value.
159410
Fixed and issue where the display of the mobile login page is incorrect after rotating the device.
159414
Fixed an issue with AutoGUI+ rules on function key buttons not being displayed when there are multiple keys in one field.
159589
Fixed an issue with the subfile options recognition on screens not containing real subfiles.
159607
Fixed an issue with popups not displaying input fields.
aXes 4.1.0.001
155366
Fixed issue where the 23rd line appeared twice after using the DDS keyword ERRMSGID
157980
Fixed an issue where the copy to clipboard functionality did not copy DBCS characters property.
158130
Fixed multiple issues where the autoColWidth was returning different values on Mozilla web browser.
158210
Fixed an issue with RAMP where the Function Key Panel was not removed when the hideFunctionKey property was turned on.
158218
Fixed an issue with extension properties not writeable after clicking the customize button.
158230
Fixed an issue where the calculation of the columns widths was returning inconsistent results on different browsers.
158254
Fixed an issue with the Group Box extension which resulted in the extension to be on top of other screen elements after being resized.
158263
Fixed an issue where the Function Key Panel was still showing after hiding all function keys.
158283
Fixed an issue with the copy as text functionality where fields with attributes DSPATR(ND) would also be copied.
158305
Fixed an issue where an object was not returning the correct property type.
158306
Fixed an issue with dropdowns where clicking the scrollbar would make the dropdown panel move in some cases involving jQuery.
158327
Fixed an issue causing the input box to be of different size in Microsoft Edge browser. This was due to the calculation of element returning different results.
aXes 4.1.0
151769
Added the option to hide/show the Spool File and Data Explorer menu items.
153067
A feature has been added so that different font library in TS-2 and aXes mobile can be defined.
154448
Added placeholder property to MultitypeInputBox and MultilineInputBox extensions
154803
Fixed an issue with assigning a base style on the quick pick menu extension.
155174
Added the following properties to axImage extension.
  1. altImageName
  2. altImagePath
  3. altText
155827
An enhancement has been added where the property "type" has been included to the Application and Screen window extension.
155883
An enhancement has been added where the popup window position properties can be included in the Application and URL.
155933
An enhancement has been added where the property SnapToGrid has been included in the Grid Settings menu.
155941 --- Fixed an issue which caused the user to change screen by accidentally pressing enter while settings the styles.
156094
An issue has been fixed where the DDS keyword "CHANGE(nn 'MDT INDEX')" did not raise the change event correctly.
156128
Enhancements have been added to the styling toolbar by adding icons and alignment options.
156138
fixed an issue by restoring the "hidden" and "tooltip" properties of PushButton.
156334
Fixed an issue where items in dropdown extension were not able to be altered using a script
156352
An enhancement has been added to the Multitype Input Box extension to include more HTML5 input types.
156387
Fixed a problem with the checkbox extension display not updating even after a change in its value.
156431
Fixed an issue with labels where 2 label superposed were creating a blurred effect.
156481
Fixed an issue with the timing of server code creating a race condition.
156626
Fixed an issue where the position of screen elements was calculated incorrectly.
156709
An enhancement has been added to automatically hide page marker fields/extensions when subfile scrollable table is used.
156713
Added the scrollBarAtTop property to indicate whether the scrollbar on the subfile scrollable table will initially be displayed at the top or bottom.
156717
Added the functionality to allow the axSubfileEnhancer extension to be moveable.
156728
Added an option in AutoGUI tab to disable legacy systems' function key names restriction.
156740
Fixed an appearance issue where check boxes did look different in output fields.
156750
An enhancement has been added to AutoGUI where a date field can be recognized.
156783
Fixed an issue with jQuery themes taking precedence over the application 5250 attribute styles.
156806
Fixed an issue with customized field being displayed even though its visible property is false.
156841
Fixed an issue with the keepLastActiveTab property of the tabs extension not working properly.
156883
Fixed a problem with input fields values in subfile scrollable table that cannot be cleared.
156890
Fixed an issue where the event ErrorDetected did not fire when expected.
156891
Fixed issue with input fields' borders not properly displaying in Chrome.
156956
Fixed a problem with DDS Scrollbar scrolling creating error with subfile input processing.
156988
Added an option in AutoGUI to be able to choose which extension to use for subfile tables.
156994
Added new properties in Keypad extension.
  1. Change keypad layout
  2. Enable/Disable keyboard input
  3. Randomise keys
  4. Text display on top of keypad
  5. Change the name from jQuery keypad to just Keypad
157005
Fixed an issue with the Scrollable Subfile Table not being able to load additional pages after error was returned from server.
157018
Added application style support for the SETAXESTHEME and GETAXESTHEME API.
157056
Fixed an issue where the Google Chart eXtension does not display correctly in aXes-TS.
157086
Fix an issue with error message parseError to be handled correctly in Firefox which caused Firefox to display AXS8203 message.
157101
Fixed an issue where the computation of the width of the extension's element was wrong.
157129
Fixed an issue where the information from one screen bleeds into the next screen.
157149
Fixed an issue where the shortcut key for TOGGLE ITEM had to be modified to prevent conflict with inputting the SPACE character in input boxes.
157221
Fixed an issue where checkboxes were not displayed correctly when DSPATR(PR ND) is used.
157224
Fixed an issue where the eXtension MultiTypeInputBox fires an event twice when using the type file.
157255
Fixed a problem with Subfile Scrollable Table's PageUp and PageDown buttons not functioning as expected.
157267
Enhanced the copy of an item to make the name of the copied element unique.
157376
Fixed an issue where the dropdown extension was not processing the onFocus event correctly.
157412
An enhancement has been added to allow the default element of a drop down to be set.
157449
Fixed an issue where the Dropdown eXtension does not fire an onFocus event in some cases when using Internet Explorer.
157586
Fixed an issue where the tabbing behavior was different in aXes and 5250 screens.
157687
The logon screen has been enhanced and redesigned.
157690
Fixed a problem with non-visual extensions not receiving focus when tabbed into.
157735
Fixed an issue with Application Styles causing background issues on fields.
157768
The axes product homepage has been enhanced and redesigned.
157839
Fixed an issue where input fields size calculation was incorrect.
