populating a dropdown with information from the screen
Post by Dino » 22 Dec 2022, 05:05
Been playing today with this, the only particular detail is to be aware that the array is of an object that contains values and text.
So, if you have a screen like this one:
and you want to have the input field code, to have a dropdown, using the values listed below, you could first identify the screen, also identify the field containing the 1=aaa 2=bbb etc for example as "options", then, bring a dropdown in the input field "code", leave the dropdown as Fixed Values, and select the script for fixedValues, click edit:
you can use this script there for example, which basically moves the string in the screen to an array, temporarly each entry is also split by the = character and the two halfs are used to populate value and text, adding entries to the returnValue array:
/* move the string 1=aaa 2=bbb etc to an array format {"1=aaa", "2=bbb", etc. } */
let arraytxt = (FIELDS("options").getValue()).split(' ');
/* clear the array */
ENV.returnValue = [];
for (let i = 0; i < arraytxt.length; i++) {
  /* convert the array entry in another temporary array for example tmp[0] = 1, tmp[1] = aaa */
  let tmp = arraytxt[i].split('=');
  /* put it together as an object  and add it to the array*/
  var  object = { value: tmp[0], text: tmp[1]};
  ENV.returnValue.push(object);
more info here:
https://axesdocs.lansa.com.au/index.php ... 50cmllcyJd
